I am trying to model compression (IMPOSED DISP) of a bead (LAW40) between platens (LAW2) in radioss. Top and bottom contacts are defined using INTER/TYPE7 with the following values (Istf-4, Inacti-6, Iform-2).
There is no penetration at the bottom contact, whereas penetration of bead into the top plate is seen.
Any suggestions to overcome this issue?
Thanks,
Arun
