I set up this very simple simulation on Flux3D (steady state thermal):
The inner volume is set as conducting region and is set also a small heat source.
The outer volume is set as conducting region ( for example air, to see the effect of conduction without convection).
The outer surface is set as "Imposed temperature on one boundary " region.
I check physics and I get this error:
Failed execution . Recommendations not available for thermal applications.
What i'm doing wrong? Is the simulation physically uncorrect? Do I need an infinity box (and if yes how?).
Thank you
Gianluca
