How extract s-parameters in EditFeko
User: "Mike_21335"
Altair Community Member
Updated by Mike_21335
I have an array of receiver/transmitter antenna point located on the same plane.(our antenna are modeled with just point source). I have a simple object in front of my array. I wish to perform synthetic aperture radar imaging. So, I want to transmit signal to the image in transmitters' locations and receive reflected waves and calculate s-parameters from transmitters to receivers. at first I thought I have to receive scattered electrical field. my code is something like this:
** source
!! for #iT=0 to 15
!! for #iR=0 to 87
A5: 0 :  :  :  :  : 1 : 0 : #Tx[#iT] : #Ty[#iT] : 15 : 180 : 0   ** ElectricPoint1
** #Tx[#iT] : #Ty[#iT]  are "x" and "y" coordinates of transmitters
** StandardConfiguration1
NC: StandardConfiguration1
DA: 0 : 0 : 0 : 0 : 0 : 1 :  :  : 2
** Near field: NearField1
DA: 3 : 2 : 2 : 2 : 0 : 1 :  : 0 : 2
OF: 1 : 0 :  :  :  : 0 : 0 : 0 : 0 : 0 : 0
FE: -3 : 1 : 1 : 1 : 0 : #Rx[#iR] : #Ry[#iR] : 15 : 0 : 0 : 0   ** NearField1
** #Rx[#iR] : #Ry[#iR]  are "x" and "y" coordinates of receivers
!!next
!!next
** source
But when I watched this video:
(1) Synthetic Aperture Radar Imaging using Back-projection - HFSS and MATLAB code - YouTube
I changed my mind about it and decided to extract s-parameters. I do not know how to do it. at first, I ran this code:
** source
!! for #iT=0 to 0
!! for #iR=0 to 87
L2: -1 :  :  : 0 : 0 : 50 : 0 : #Tx[#iT] : #Ty[#iT] : 15 :  :  : 0   ** source
LT: 0 :  :  : source : 0 : 50   ** source
L2: -1 :  :  : 0 : 0 : 50 : 0 : #Rx[#iR] : #Ry[#iR] : 15 :  :  : 0   ** sink
LT: 0 :  :  : sink : 0 : 50   ** sink
SP: 1 : 0
!!next
!!next
But It results in the following error:
ERROR 17: Undefined wire port node/connection point
1 - 3 of 31
    User: "Raja Devata"
    Updated by Raja Devata
    Good to hear from you.
    It will be easy to perform this kind of simulations using CADFEKO (rather than the EDITFEKO) and request the S- Parameter configuration from the request tab.
    Here is the screenshot to request the s-parameter configuration.
    In the same way, You can request the S-Parameters request from EDITFEKO.
    I am sharing the example files for your reference which is having the s-parameter request (Both in CADFEKO & EDITFEKO).
    You can use lua scripting or Altair compose software to write the script for Synthetic Aperture Radar Imaging.
    Thanks!
    Raja.
    User: "Raja Devata"
    Thanks!
    Raja.
    I am attaching the files. Please go through them.
    Thanks!
    Raja
    User: "Mike_21335"
    OP
    Thanks!
    Raja
    hello @Raja Devata ,
    Thank you for your helpful answer. But I think there is a problem with ".cfx" file. Because it results in the following error:
    Error 17604: an error has occured while opening the project. Please check error message window.
    There was no "message window" to bring the content here. can you please post it here? because I can not run ".pre" file without that.
    Thank you so much
