I am currently trying to simulate a very flexible material in EDEM using the bondingV2 model. However, to achieve sufficient flexibility I had to use a low bond stiffness. But that caused the bonds to break due to particle seperation. Now I could increase the contact radii, but then bonds form over other particles, and not just with nearest neighbours. which then results in a rigid truss like structure. How can I fix this?
Matthias
