I have a spider of CBARs that I want to change into CBUSHs using Hypermesh. If I use the 'config edit' panel it creates 1 noded CBUSHs, since CBUSHs are created under the 'masses' panel.
How can I make this change?
Thank you.
Phil Brown
I found the problem.
CBUSHs can also be defined in the SPRINGS panel. Those take two nodes. Problem solved.
One of those things you apparently just have to know.
Phil
