Me and my collegue are trying to visualize the different plies of the composite after the implementation of those and the creation of the laminate and material. How could we visualize them?.
Thank you in advance.
Hi Begoña
Please check this video. I hope it can help you.
https://insider.altairhyperworks.com/composites-visualization/
Thanks
Hello Pranav,
We have watched the video and checked our model. We are still having problems to visualize the composite. We think it could be a problem with the previous steps creating the material ,properties, etc...
Could you send us a video tutorial about implementation of composite materials and properties in Radioss?.
Thank you very much.
Please have a check whether these document can help you
@Begoña attached is the model with composites. Try to setup you model in similar fashion. P17 stack property can be used instead of P51. Use the XREF entity (right click entity in browser) to check how different entities (plies, laminates, materials and properties) are referenced and related to each other. If the plies are too thin to properly visualize, go to Preferences>Graphics>ply visualization thickness factor.
Hi Begoña Please have a check whether these document can help you Thanks Unable to find an attachment - read this blog
Would you share other chapters of this training if you have them ?
