Hi there,
I am reviewing results from a harmonic analysis. Is there an explanation for the results difference between the probe display and the chart ?
The software version is 2019.4.1.63.
Best regards
It is strange to see the probe stress result (36MPa) beyond the stress range of the chart (33MPa).
Could you please share this SimSolid file?
