Hello
I am trying to reduce the axial ratio on a LHCP truncated patch antenna, however having little success using the Nelder-Mead method.
For the goal, the focus type is E-field, polarization is axial ratio, the operation is minimum and the operator type is minimize.
I have selected a few parameters to vary.
Is this the correct way to set up an optimization of this type or can anyone advise on other configurations?
Thanks
