I have a linear static simulation where I'd like to apply the same load at multiple angles. Rather than create multiple load steps for each angle, I'd like to set the load such that it's driven by a vector driven by a curve or equation. Ideally the analysis would then be performed at each XYZ vector step in the curve. Is this possible in Hypermesh/Optistruct? Is there a better way to do this than what I'm attempting to do?
For some more context, this is essentially a simplified drop test. The load is the weight of the object and the varying angle is because there are multiple angles at which the object can impact the ground, so I want to change the load vector at the center of gravity to mimic the deceleration of the CG. This is a study on the internal ribbing structure supporting the CG and not on the external failure due to impact with the ground.
Any insight would be appreciated.
