I encountered a bug in hyperworks tcl command
Client Version Command Bug Information
Hypermesh 12 *findmark elems 1 1 1 elems 0 2 this command did not add elems of mark 1 to mark 2
it works for me... the findmark function will return the attached elements to the provided elements. If you need the original elems, append them to the mark.
set elemIds <list with given elems> hm_createmark elements 1 $elemIds; *findmark elements 1 1 1 elements 0 2; hm_appendmark elems 2 $elemIds set elemList [ hm_getmark elems 2 ]; puts $elemList;
Remember that the list contains the HM elems ids, not the solver elems ids. To get the solver ids use:
hm_getsolverid2 elems $elemIds
I encountered bugs in hyperworks tcl command
So you should care about these
Hypermesh 12 *findmark elems 1 1 1 elems 0 2 this command did not add elems of mark 1 to mark 2 regardless the specified option
