Stop Activate simulation in Initialization script or Diagram-Context script
RoKet
RoKet
edited June 2021 in Community Q&A
A few days ago I saw this interesting question with the additional explanation
"Are there any oml commands to stop Activate simulation which can be used within Initialization script or Diagram-Context script?
I use Diagram-Context for some pre-processing (getting data from other tool) for Activate simulation, but if a result from the pre-processing is wrong Activate simulation doesn’t have any meaning and I want to stop it before starting the simulation."
The answer is "Yes!". This can be done very easy by adding a return command in case of wrong pre-processing
  if wrongPrePro
return;
end;
In the diagram context you can alternatively use the error function (and include even additional information in the message)
  if wringPrePro
error(‘Pre-processing error.’);
end;
In addition to stop the complete simulation on top level you can use the return command in diagram home context of a super block to exclude the execution of this super block from simulation. I use it e.g. to switch the writing to file on or off.
Thanks for answers to Ramin and Manoj KV.
Welcome!
Welcome!
