After i do computation on my silmulation how can i get only some specific files that i need such as Cell.txt, SINR.txt.... I don't need to get all files since all the files i get are very big: ~32Gb and it need alot of time to write that files~1h
Under the Network tab of the project parameters you can select which results will be computed:
For the cell assignment (cells.txt) the best server option needs to be selected.For the SNIR results the option Serving Carrier: SNIR (cell assignment).
