Problems running FSI heat transfer analysis with OptiStruct
Apostolos Lazios
Altair Community Member
I am trying to run a heat transfer FSI analysis and i keep getting this error : ABORTING RUN DUE TO UNEXPECTED ERROR CONDITION.
I am following the steps from OS-T: 1610 Thermal Fluid-Structure Interaction Analysis on a Manifold.
What can i do to fix this?
Hi
What is the version of OptiStruct and AcuSolve you are running?
Could you share the *.out file of the OptiStruct run that is ending with error?
Thanks and Regards
0 -
hi,
I faced the same error on this tutorial.
This Thermal FSI can only be run using OS & Acu v2019.0.Other versions will result in error like yours.
Additionally, in the FSI card on OS model, you need to set FSI Data = 3.
The tutorial guide is wrong when show the FSI data = 1.
