Hi everyone,
I keep getting 'WARNING ZERO OR NEGATIVE VOLUME' errors when I run my setup.
I have tried using default fscaling for the material curves because I was using different units than the tutorial but that would create a weird expanding behavior and still result in the same error. I based my setup off of the crashbox tutorial but it does't address or explain this.
