I am working on simulations of antenna buried at depth 1m in ground. I would like to perform couple of simulations including different soils (sand, dirt, higher water content etc.).
- Is there any example of a similar problem?
- What would you recommend to decrease the simulation time (even simple PEC suboid of 2x2x2 with planar antenna inside was simulating whole day unless i made a mistake)?
- Do i just need to place the antenna inside a soil model and start simulations or do i need to follow certain steps to do so?
I am fairly new to FEKO and that kind of simulations, thanks in advance for your time.
