Overwrite .out file on each run
When I run OptiStruct I get xxxx.out, then when I run I get xxxx_1.out, then xxxx_2.out on the next run and so one. I am having matlab read my .out file and running OptiStruct through it as I go, so I need it to keep overwriting the file as it goes. How can I make it so I get only one output file that keeps getting overwritten?
Thanks in advance
Edit: Sorry, immediately after I posted this I found a solution. In case anyone happens to be looking for it ever, here it is:
1 - 1 of
11
It seems that the link in the question is down, but https://help.altair.com/hwsolvers/os/topics/solvers/os/syssetting_io_r.htm?zoom_highlight=savefile
Thanks, i didn't know this.
