I am trying to run RADIOSS on my group's local cluster. I know for a fact my simulation runs, however it is getting blocked from running. My system administrator thinks that this is because the cluster queuing is running the starter file, but then when the starter initiates the engine file, it is blocked by the queuing system. Is there a way to tell RADIOSS to split the starter and engine jobs to run separately? I realise this is quite the arbitrary request, so if you have any questions let me know. I'm not really sure where to start with this, and am looking for someone with experience setting up RADIOSS on a cluster.
Thanks,
Ayman
