ANALYSIS RESULTS :
*** INFORMATION # 1420
Unsupported solution sequence, switching run to serial mode.
*** WARNING # 1418
Parallel OptiStruct (-ldm) cannot handle some subcases defined.
Switch to serial run or parallel run with domain decomposition method (-ddm).
I am getting the above warning message, i need to know the reason for this message, is this because of the SMP run?
Chethan
