How to give Prtension for 3d bolt ,1d bolt and run in two steps in radioss 2019
Do you mean to 'sequence' your pretensioning?
Radioss doesn't have 'steps' as such like an Implicit solver, everything is in time domain, so if you are using SPR_PRE for example for pretension, you can specify different load/time curves for your pretension springs, or use time sensors with a delay in order to sequence your pretensioning.
