AcuSolve results can be visualized in HyperView or AcuFieldView.
HyperView is the easier option for most users (especially if you have used HV for some other solver). HV is a generic post-processor, so only basic CFD post processing is possible. However it covers the needs of many users.
AcuFieldVIew is the expert tool for CFD, with advanced features for CFD post-processing. As with expert tools, it takes time to get used to it.
So if you are new CFD user HV might be a good first choice.
HyperView:
HV can read results in following formats:
1.AcuSolve .Log file with ACUSIM.DIR in the same run folder.
2. Convert AcuSolve results to H3D
a. AcuConsole > Tools > AcuOut.
2b. AcuOut is using the command acuTrans to convert the files. This command can be executed directly from the AcuSolve Cmd Prompt .
AcuFieldView:
Similar to above process for HyperIvew, you can export files to ..FV format as well.
