On the EDEM help they said that "The Field tab is only available when you have purchased the Field Data Import Module" and I don't get what they mean by that
Hi Soraya,
I see what you mean in the documentation, this is an error left over from a previous version of the docs, where field data was a licensed feature. This isn't relevant now as it's included as standard.
Regards
Stephen
Hi thank you for replying.
Still not able to use it. i can't even chose a field.
Hi thank you for replying. Still not able to use it. i can't even chose a field.
This may be because you are using the student edition?
https://web.altair.com/altair-student-edition
The student edition is limited in functionality (product limitations shown 3/4 way down the page in the above link.
Hi
No it's not a student edition.
I can't even chose a field or check the display field name
Do you have a field imported in the Creator Tree > Physics > Field Data Manager?
We have a tutorial on the field data:
Field Data Tutorial
The importing field component is shown in Step 1.
