Im trying to do a Carbon sheet for a motorcycle aluminium frame to reduce mass and keep the stiffness. Any sugestion?In the image, at blue in my frame and at pink is my carbon sheet.
First i designed my frame in Inventor and added a surface to put my carbon plys.
if the element is contained into a component that has the PCOMPG property, then it should be refereneced as well in at least one ply of your stack/laminate.
Maybe you've missed this (and potentially other) element in adding it to a ply/laminate.
if the element is contained into a component that has the PCOMPG property, then it should be refereneced as well in at least one ply of your stack/laminate. Maybe you've missed this (and potentially other) element in adding it to a ply/laminate.
And what is your suggestion to correct that?
