It depends on the solver interface.In OptiStruct you can create a load collector with the LOADADD card to collect several load collectors to include in a load step.
My solver is the OptiStruct. So, how can i do it?
create a new load collector change the card image to LOADADD (see above) change LOAD_Num_set to the number of load collectors you want to include select the load collectors (table button for more than one, then the table below will open) optional: change the scale factors
This is if you want the different loads in the same load step. You could also create multiple load steps with different loads.
If i want to create multiple load steps with differente loads is the same process?
I have this error when i run the simulation. Any suggestion?
If i want to create multiple load steps with differente loads is the same process? I have this error when i run the simulation. Any suggestion?
You can't add a load collector to itself. The loadadd load collector you are showing has an id of 2 and you are also calling load collector id 2 within that load collector. Remove the load collector 2 from the list.
Yes, just create multiple load steps and reference the loadadd card or a single load collector as desired.
