Is it any support documentation where I can find the equations supported the 12 models used for fluid problems ? I would like to understand the difference between them and what are the parameters involved.
The documentation available is in the Help system for AcuSolve 2018. The default location on Windows: file:///C:/Program%20Files/Altair/2018/acusolve/win64/help/acu/index.htm
Get Started > Altair AcuSolve Training Manual > Theoretical Background > Turbulence > Modeling of Turbulence
Other than that, you can find general documents for the models in the public arena - published documents by others.
I have this version:
Do you know if we have available same info in this versión ? I could´nt find it.
Thanks
From AcuConsole, try
Help >> AcuSolve Help
and see if it takes you to the on-disk documentation.
