Hi there, when running my simulation using polyhedral particle, an error message occurs stating that the Oka_Wear.cu plugin file does not exist. Currently, i am using Oka_Wear.dll file as my plug-in. My question is, do we need a different type of plug-in model file type for GPU solvers? The .dll file can run when I use the CPU option but for polyhedral particle, I can only run in GPU, there is no option for CPU. I have attached some images help showcase my problem. Can you help me understand what is really going on here as i am new to this EDEM software. If there is a Oka_Wear.cu plug-in file, could you please share it. Thank you.
