Hi All,
In the HyperMesh 2020.0,I remember that you can press Shift+left click to open a menu and choose it by the last column,like this:
but in 2020.1, the last column is missing,like this
Where can I find them?
Thanks advanced !
It should still be there, but it changes based on your selection type. For example, if you go to the Mask panel and select elements, you should see the additional row.
That's very helpful,thanks
