Hello Everyone,I am new to hypermesh, is there an option to paste 2 nodes together? I know about equivalence but for that the nodes should be in the tolerance limit. Can we manually select 2 nodes to be pasted?
Hi, Go to 2D> Edit element > Replace and select the 2 nodes . ( refer the attached image) Regards Prajval
Regards
Prajval
Yes, the same option is available in Legacy hypermesh too.
You can find it under 2D panel> Replace.
Thank you, is this option also available in hypermesh or only hyperworks?
