After the radioss analysis .rst files are created but there are no .h3d files.
Then, I am not able to view my results in Hyperview.
Does anyone know this?
Thank you for helping!
Have you set the ANIM/DT animation output frequency card?
@Ivan I haven't done it yet.
But after making the .h3d file up.
Thank you very much!!
hello Sukwasa,
make sure if u run from hypermesh (radioss) module -noh3d must not be there as shown in below image.
If u got A001 A002...files, just open one of them in hyperview.
How to merge all animation files into a .h3d file?
Thanks ,
Narasimhamurthy
use HvTrans tool to convert animation files A00 to h3d file.
