Dear FEKO team,
I would like to ask a question regarding the simulation of an antenna structure in low frequencies. I am simulating a crossed dipole antenna in the frequency range 20MHz - 100MHz, which is purposed for radioastronomy applications. The antenna has a finite ground plane which I simulate as a rectangular surface, and an infinite lower half space of soil. Due to the required accuracy of the application, the soil which is underneath the antenna and which has been measured to have different complex permittivity at different depths, has to be modelled in multiple layers, so I used the option "Infinite multilayer substrate". The problem is that, as I have realized by using one layer and the options "Reflection Coefficient Approximation" and "Exact Sommerfeld Integrals", the latter one is the only accurate method for lower frequencies. When I switched to multilayer substrate and run the model, the solution for zenith Gain was closer to the results of the "Reflection coefficient approximation" for one layer, so I assume that this approach is also used for the multilayer substrate.
My question is, is there any other way I can achieve the same accuracy as that of the "Exact Sommerfeld Integrals" in the low frequencies, when using a multilayer substrate? I even tried to model the first layers as finite cuboids of dielectric medium solved with FEM (hence a hybrid approach with MoM) but I get an error from the iterative solver BiCGSTAB:
"Maximum number of iterations reached without convergence" with a norm error of the order of O(0.1), whereas the criterion for convergence is O(10^-5)
I would appreciate any advice. Attached is an image of the comparison between "Reflection coefficient approximation" and "Exact Sommerfeld Integrals" where the discrepancy is visible, and an image of the multilayer substrate model which produces similar results as the "Reflection coefficient approximation".
Thanks in advance,
George
