I had a problem trying to import some results file(.h3d) from optistruct to hypermesh. It appears at the bottom of the screen: "*setvalue: Could not modify value for dataname/attribute: resultfiles". Can anyone help? Thank you.
Hello
Can you please specify HOW you are importing (through Post ribbon)?
You may want to try deleting your settings files and try again
You can directly use the cleanup script shown below by double clicking on it from the installation folder location
Thanks
