In Hyperworks software. The Ethernet address of license is not matching the address in the Run command from windows, it says invalid license please respond if you can help.
do you mean your license ethernet is not matching any of your network adapters showing in 'ipconfig -all'??
If that's the case, you will need a new license with the correct ethernet address.
Are you using a Student version? Or a full commercial?
