I am trying to finish my model but there is errors and warnings occur.
And for the warning that says initial penetration, i have modified the geometry and it still keep happening.
how can I solve the problem?
Hi
For ALE you need to use Isolid=1
The other error related to interface and not able to change nodes, it can be the case that the nodes are related to /RBODY or nodes are associated to /BCS or other imposed kinematic condition.
I hope this helps
Regards
