I can´t install the Products Installer on my Laptop with Windows 11.
There always is this window with this failure.
It isn't officially supported so your 'mileage may vary', you can try:
setting
JAVA_TOOL_OPTIONS="-Dos.name=Windows 10" in Environment Variable.
It isn't officially supported so your 'mileage may vary', you can try: setting JAVA_TOOL_OPTIONS="-Dos.name=Windows 10" in Environment Variable.
Dear Sharp
Thank you so much, wow, it works.
Best wishes
Sunny
