Hi, I am trying to use the coil loss tool. But when solving the project, it requires me to close the project. Could you help?
the warning in yellow is probably due to some windows being opened while doing something else. Like If you keep the window to edit the region open and try to solve, the window is not synchronous. Everything should be greyed out as you will be in solved state.
If everything else is correct and the project is solved then this is it, just close the Edit windows before solving.
Cheers
Hello, the warning in yellow is probably due to some windows being opened while doing something else. Like If you keep the window to edit the region open and try to solve, the window is not synchronous. Everything should be greyed out as you will be in solved state. If everything else is correct and the project is solved then this is it, just close the Edit windows before solving. Cheers
Thank you. but I confirm that the Edit windows all closed.
If I set to "not compute the coil loss", then the project is all OK.
lost....
Thank you. but I confirm that the Edit windows all closed. If I set to "not compute the coil loss", then the project is all OK. lost....
Sorry for the confusion I thought the main error was the warning. I understand then that it does not solve.
I guess the coil model with losses needs to run Flux servers as submodels. Can you chek the Flux servers are enabled ? Do you have a green light on Distribution manager from the Flux supervisor ?
If no, run the supervisor in admin mode and click on Distributiuon manager, it should run a batch script that resets it
