By checking the .o log file, I see:
Does that means only one core is used? causing the solving time is quite long.
if so, what can I do to use all the cores?
My batch file is :
#!/bin/bash
# Request 8 cores in an MPi environment
#$ -pe mpi 8
# Request 256 gigabytes of real memory (RAM) 8 cores *32G = 256
#$ -l rmem=32G
# load the module for the program we want to run
module load apps/altair_flux/binary/2021.2
# Use fixed values for the GUI-memories
export JVM_MEMORY=1000 # In MBytes
export MEMSIZC3=0 # In Bytes
export MEMSIZN3=0 # In Bytes
# This allows multiple instances of Flux
export SYNC_SOCKET=0
# --- Making the command line ---
# Specify the path to use executable of Flux
PATH_TO_FLUX_EXECUTABLE=/usr/local/packages/apps/altair_flux/2021.2/binary/altair/flux/Flux/Bin/prg/lin64/flux
# Specify the python script to execute
YOUR_PYTHON_SCRIPT=/home/els20wz/Downloads/hpcfluxtest.py
# Get the application of the python extracting its header
FLUX_APP=$(head -n 1 $YOUR_PYTHON_SCRIPT | cut -d ! -f 2 | awk '{$1=$1;print}' | cut -d ' ' -f 1)
# Launch Flux
$PATH_TO_FLUX_EXECUTABLE -application $FLUX_APP -runPyInSilentModeAndExit $YOUR_PYTHON_SCRIPT -batch
