Can a Flux project be exported as a Python script? I am planning to run a Flux project on another computer with python but without Flux installed (some authorization issue).
Hi Wenjun Zhu,
At the moment a Flux Project can not be exported as a Phyton script file.
You need to create the file yourself.
All operations performed in Flux have the equivalent PyFlux commands written in the Flux2D_log phyton script file.
The simplest way to create the phyton file is to define your Flux project from scratch and then get the PyFlux commands written in the Flux2D_log phyton script file, if you do not have the Flux2D_log phyton script file from the definition of your Flux Project.
Best regards,
Alexandru
