Is there a way to create the PWL voltage source by a text file, which has the information below?
Second Voltage
0.0006 120
0.0007 121
0.0005 120
Jaesoo Byoun
yes, very easy please use a lookup table and a controlled source.
This tutorial video explains how lookup tables can be used
controlled sources are here, you can do the same with currents sources.
