Merging into single model - Model with transform card
For Radioss, I prepared a model with bunch of includes. And few of those include has a Transformation card. But later realised Radioss won’t support node set in transform card, Instead I need to create a //SUBMODEL to use then with /TRANSFORM card.
To avoid confusion, would like to merge the model and export without transformation details. Where can I find option to merge the model and overwrite the transformation details in Hypermesh.
Thanks & Regarrds,
Naresh Kini
Hello Paul,
Thank you!!.
I could merge the data into single file, but still TRANSFORM data still exist. Since I am facing issue in retaining transform in the model, I would like to merge and eliminate the transformation details in my model.
Example: In Primer we get a option to eliminate the transform and parameter details while exporting file.
Naresh Kini
I think you can delete the transformations in HW before export and it gives you the option of keeping the current position or returning to the untransformed position?
Hello Paul,
I did tried that option but did not got any such pop up to retain the model in desired position. But will try one more time incase I missed to see any popup message/warning.
Thanks,
Naresh Kini
Yes, ok, I was mis-remembering, it is HC has that option. Can you share the model (here or via Altair Support) so we can investigate the root of the problem with the transforms?
In the options when you export, there is a pulldown for merging or preserving includes: you should be able to simply toggle to 'merge' and the file will be written as a single model (default is to preserve)
