Restart file not created - how to find the error?
Hi all,
I am running a simulation on Radioss solver.
After some iterations, the simulation fails, without any clear message on the reason. From the terminal:
NC= 45000 T= 5.8073E-03 DT= 1.2905E-07 ERR= -8.2% DM/M=-4.0935E-15
ELAPSED TIME= 8296.17 s REMAINING TIME= 13846.82 s
Restart file 3_stages_0001_0001.rst was not created.
Missing "NORMAL +TERMINATION" in output file 3_stages_0001.out.
Solver FAILED
Radioss:: Solver run finished after 2 hours (9776 seconds).
Opening the file 3_stages_0001.out, I cannot see any indication, the last lines are like:
ANIMATION FILE: 3_stagesA008 WRITTEN
45000 0.5807E-02 0.1291E-06 SHELL 900083534 -8.2% 1009. 257.5 0.1723 1380. -0.4094E-14 0.7284E-04 -0.2982E-18
Is there a way to know what is causing this?
Thanks for the help
Good morning Harish,
thanks for the reply. Here are the files.
I am simulating a 3-stages process. Before, I was simulating each step independently and importing the deformed part shape each time. Now I modified the same simulation to solve in a single step.
Hi Good Morning!
Restart file will be generated by requesting in engine file using /RFILE as shown in attached picture.
But for error you need cross in the out files, please send the both starter and engine out files.
Regards
Harish
