When I define a custom operation with top die, bottom die, top binder, bottom binder, the simulation will terminate due to an error when reading the bottom binder spring's curve.
In particular, I can see from the .rad file that the points on the x axis are not defined correctly:
I can modify them manually and solve with radioss solver, but I would like to solve tha analysis directly from Inspire Form.
How can I avoid this error?
