I would like to set up a parametric study in Inspire Form. My goal is to evaluate the final blank shape for a certain range of binder force.
Hi,In Inspire Form, there is no direct option in the released versions to set a certain range for the binder force, you can only define the force for the binder, or define the gap to get the automatic binder force calculated by Inspire Form.For your requirement you need to run the manual iterations by changing the Blank holder force manually.Thanks and Regards,Saurabh
