Can some one help me with dissecting component names. I have a multiple assemblies one has components other has weld lines. Weld lines have base components name in it.
Example of a weld line component name
2 layer line
LA7273333/2-012234 WLD LNS (X02704/X03430)
3 layer line
LA72733425/2-010104 WLD LNS (X513A12/X02704/X03430)
Example of components names
AA6383837/5-XXXX-X02704-A (PLR FRT uPPER RR FRONT)
AA671617033/5-XXXX-X03430-A (SHLD HDR REINF)
LAA6716635/4-XXXX-X513A12-A (RL RF SD FRT LHS)
I would like to look inside the weld line assembly pull out a name of the weld line sort 2 layer of 3 layer based on name inside the ( ), use the naming inside ( ) from a line name, find the components and create a connector.
Thank you for any help
