How I can update the density of a body imported by the tool "Import CAD od FEM using Hypermesh" to update automatically the inertia properties of the body?
Hi Daniele - the density of the bodies cannot be adjusted after importing CAD or FEM using Hypermesh.
You can however
1. Change the mass/inertia by multiplying the existing values by any factor
2. Use the Import Geometry tool to import CAD. Then the graphics CAD can be assigned a user-created Material whose density can be varied or use any other pre-defined Materials
Regards
Praful
Hi Praful, thanks for the replay.
Daniele
