I just downloaded the install file and hotfix for the Hyperworks 2021.2 suite.
The installation script correctly run through and there is nothing suspicious in the logs. However, when I start the program from
./INSTALL_PATH/hwdesktop/script/hwx
I receive the following errors:
INSTALL_PATH/hwdesktop/scripts/hw: 101: /home/benutzerin/2021.2/altair/hwdesktop/scripts/invoke/common.sh: [[: not found
INSTALL_PATH/hwdesktop/scripts/hw: 125: [[: not found
INSTALL_PATH/hwdesktop/scripts/hw: 318: [: hw: unexpected operator
INSTALL_PATH/hwdesktop/scripts/hw: 331: export:0x8400038: bad variable name
I cannot identify the problem in the Hyperworks logs.
Does someone have an idea what the probelm could be?
Thank you in advance,
Roxana
