Hi Everyone,
I have a 3-D truss structure to make bending analysis. So, I converted the analysis 3D to 2D by making a mid-surface operation.
But when I use mid-surface for box-section profiles, gaps showed up between surfaces, naturally.
I would like to ask how I can eliminate the gaps between surfaces? and should I do this editing with surface edit commands or mesh edit commands after meshing operation?
You can see the red lines in the below figures.
