Currently, I'm using AcuSolve to simulate a CFD problem. However, I'm encountering an "Inlet" error as shown in the image. How should I handle this error?
Thank you very much.
Can you provide your model?
Yes - probably needed. It looks like the Inlet BC has been applied to surfaces where the parent solid bodies are assigned different medium/material. Make sure the solid bodies are assigned the correct/desired material. Also good to assign separate boundary conditions (so in separate sets) if the surfaces are topologically disconnected.
Here is the file I set up in Acusolve
https://drive.google.com/file/d/1shtTK4eaJV2mYWRPsV79caSJN4UuxcsI/view?usp=drive_link
Here is the file I set up in Acusolve https://drive.google.com/file/d/1shtTK4eaJV2mYWRPsV79caSJN4UuxcsI/view?usp=drive_link
For starters, can you just add the input file (.inp) and Log file (.Log) here in the forum - as attachments?
All files are in this link, thank you
https://drive.google.com/file/d/1yZWriQO72NE-jXKNl59k7T3qVEtaDNMz/view?usp=sharing
