I'm currently following a tutorial and I can't find where to set " run execution time parameters" in Simlab 2022.3.Can anyone tell me where to set this parameter in simlab 2022.3 ?Thank you
This option is moved under "Create solution" dialog. Go to "Solutions > Applications > Drop Test".
Thanks & Regards,
Santhoshkumar
Additional note: if you want to edit this parameter after creating the solution, please just double click on the solution name.
