Fixing the position and spawn of 1 large particle.
User: "Dylan Meiners"
Altair Community Member
Updated by Dylan Meiners
Hello, I am trying to run a simulation with one large particle that is in the shape of a rectangle. I want the particle to spawn in a specific location with a specific orientation but every time I run it the particle has spawned at a different location on the factory. Is there a way to know exactly where my one particle will spawn?
1 - 3 of 31
    User: "jerrinjobs"
    Updated by jerrinjobs
    Hi Dylan
    In the Factory settings, you can choose the 'Orientation' to be fixed and choose the orientation you require.
    You can also choose the position (spawn) to be a specific setting (I like bcc for one particle) and specify the location where you want to generate the particle.
    Thanks,
    Jerrin Job
    User: "RWood"
    Updated by RWood
    Just to add to what Jerrin said, which is definitely the way to do this for individual or maybe even 10s of particles, if you want to specify the exact positions of, say, 100+ particles, it would probably be easier to do it in a custom factory using an API plugin.
    Food for thought.
    Richard
    User: "Renan"
    Updated by Renan
    Food for thought.
    Richard
    Just to add to what Richard said, you can accomplish the same the goal using EDEMpy.
    Best regards,
    Renan
