I am doing a simple topological optimization on a cantilever beam with point load at it's end. It is a stress constraint topological optimization. I created one response mass, objective to minimize mass and described the stress constraint within topology panel. I am doing the simulation in HPC. Now upto mesh 3d element number like 160000, the result converged. But when I increased the mesh element to 185000, it is being stopped at certain iteration and showng this- optistruct error termination report printed to the file 'Ele_den_21.stat'. I have attached two of the output file. In the first one iteration stopped at 2nd iteration, then I run it again and then the same file stopped at 18th iteration.
What can be the reason, how can I resolve it and get the converged result? From another conversation of the forum I came to know this might happen due to internal error. I don't know what does that mean. I have designed the model same way i had designed the other which were having a converged result.
In HPC optistruct is using in core or min core processing. And I am running the solver by writing command in command line.
