I want to build a Bush element between two connectors (RBE2+Spring+RBE2), that means I try to connect two body with spring 6-dof stiffness. So, how can I do this?
Hello Zhou XU,
If you are trying to create spring between two connectors under Inspire Motion tab, You can simply select spring and later select both connector points one after another. For further assistance, please create Service now ticket so expert can help you more in detail.
